RTEMS Logo
RTEMS 4.10.0 On-Line Library
CPU Usage Statistics cpu_usage_reset - Reset CPU Usage Statistics
PREV UP NEXT Bookshelf RTEMS C User's Guide
26.4.2: cpu_usage_reset - Reset CPU Usage Statistics
CALLING SEQUENCE:
void rtems_cpu_usage_reset( void );
STATUS CODES: NONE
DESCRIPTION:
This routine re-initializes the CPU usage statistics for all tasks in the system to their initial state. The initial state is that a task has not executed and thus has consumed no CPU time. default state which is when zero period executions have occurred.
NOTES:
NONE
