RTEMS Logo
RTEMS 4.10.0 On-Line Library
Stack Bounds Checker Initializing the Stack Bounds Checker
PREV UP NEXT Bookshelf RTEMS C User's Guide
25.3.1: Initializing the Stack Bounds Checker
The stack checker is initialized automatically when its task create extension runs for the first time.
The application must include the stack bounds checker extension set in its set of Initial Extensions. This set of extensions is defined as STACK_CHECKER_EXTENSION. If using <rtems/confdefs.h> for Configuration Table generation, then all that is necessary is to define the macro CONFIGURE_STACK_CHECKER_ENABLED before including <rtems/confdefs.h> as shown below:
#define CONFIGURE_STACK_CHECKER_ENABLED
#include <rtems/confdefs.h>
