RTEMS Logo
RTEMS 4.10.0 On-Line Library
User Extensions Manager EXTENSION_DELETE - Delete a extension set
PREV UP NEXT Bookshelf RTEMS C User's Guide
22.4.3: EXTENSION_DELETE - Delete a extension set
CALLING SEQUENCE:
rtems_status_code rtems_extension_delete(
  rtems_id id
DIRECTIVE STATUS CODES:
RTEMS_SUCCESSFUL - extension set deleted successfully
RTEMS_INVALID_ID - invalid extension set id
DESCRIPTION:
This directive deletes the extension set specified by id. If the extension set is running, it is automatically canceled. The ESCB for the deleted extension set is reclaimed by RTEMS.
NOTES:
This directive will not cause the running task to be preempted.
A extension set can be deleted by a task other than the task which created the extension set.
NOTES:
