RTEMS Logo
RTEMS 4.10.0 On-Line Library
User Extensions Manager TASK_SWITCH Extension
PREV UP NEXT Bookshelf RTEMS C User's Guide
22.2.3.5: TASK_SWITCH Extension
The TASK_SWITCH extension corresponds to a task context switch. If this extension is defined in any static or dynamic extension set and a task context switch is in progress, then the extension routine will automatically be invoked by RTEMS. The extension should have a prototype similar to the following:
void user_task_switch(
  rtems_tcb *current_task,
  rtems_tcb *heir_task
where current_task can be used to access the TCB for the task that is being swapped out, and heir_task can be used to access the TCB for the task being swapped in. This extension is invoked from RTEMS' dispatcher routine after the current_task context has been saved, but before the heir_task context has been restored. This extension should not call any RTEMS directives.
