RTEMS Logo
RTEMS 4.10.0 On-Line Library
Barrier Manager Obtaining Barrier IDs
PREV UP NEXT Bookshelf RTEMS C User's Guide
20.3.2: Obtaining Barrier IDs
When a barrier is created, RTEMS generates a unique barrier ID and assigns it to the created barrier until it is deleted. The barrier ID may be obtained by either of two methods. First, as the result of an invocation of the rtems_barrier_create directive, the barrier ID is stored in a user provided location. Second, the barrier ID may be obtained later using the rtems_barrier_ident directive. The barrier ID is used by other barrier manager directives to access this barrier.
