RTEMS Logo
RTEMS 4.10.0 On-Line Library
Barrier Manager Building a Barrier Attribute Set
PREV UP NEXT Bookshelf RTEMS C User's Guide
20.2.2: Building a Barrier Attribute Set
In general, an attribute set is built by a bitwise OR of the desired attribute components. The following table lists the set of valid barrier attributes:
NOTE: Barriers only support FIFO blocking order because all waiting tasks are released as a set. Thus the released tasks will all become ready to execute at the same time and compete for the processor based upon their priority.
Attribute values are specifically designed to be mutually exclusive, therefore bitwise OR and addition operations are equivalent as long as each attribute appears exactly once in the component list. An attribute listed as a default is not required to appear in the attribute list, although it is a good programming practice to specify default attributes. If all defaults are desired, the attribute RTEMS_DEFAULT_ATTRIBUTES should be specified on this call.
This example demonstrates the attribute_set parameter needed to create a barrier with the automatic release policy. The attribute_set parameter passed to the rtems_barrier_create directive will be RTEMS_BARRIER_AUTOMATIC_RELEASE. In this case, the user must also specify the maximum_waiters parameter.
