RTEMS Logo
RTEMS 4.10.0 On-Line Library
Rate Monotonic Manager RATE_MONOTONIC_CANCEL - Cancel a period
PREV UP NEXT Bookshelf RTEMS C User's Guide
19.4.3: RATE_MONOTONIC_CANCEL - Cancel a period
CALLING SEQUENCE:
rtems_status_code rtems_rate_monotonic_cancel(
  rtems_id id
DIRECTIVE STATUS CODES:
RTEMS_SUCCESSFUL - period canceled successfully
RTEMS_INVALID_ID - invalid rate monotonic period id
RTEMS_NOT_OWNER_OF_RESOURCE - rate monotonic period not created by calling task
DESCRIPTION:
This directive cancels the rate monotonic period id. This period will be reinitiated by the next invocation of rtems_rate_monotonic_period with id.
NOTES:
This directive will not cause the running task to be preempted.
The rate monotonic period specified by id must have been created by the calling task.
