RTEMS Logo
RTEMS 4.10.0 On-Line Library
Rate Monotonic Manager Deleting a Rate Monotonic Period
PREV UP NEXT Bookshelf RTEMS C User's Guide
19.3.5: Deleting a Rate Monotonic Period
The rtems_rate_monotonic_delete directive is used to delete a rate monotonic period. If the period is running and has not expired, the period is automatically canceled. The rate monotonic period's control block is returned to the PCB free list when it is deleted. A rate monotonic period can be deleted by a task other than the task which created the period.
