RTEMS Logo
RTEMS 4.10.0 On-Line Library
Scheduling Concepts Timeslicing
PREV UP NEXT Bookshelf RTEMS C User's Guide
18.2.3: Timeslicing
Timeslicing or round-robin scheduling is an additional method which can be used to alter the basic scheduling algorithm. Like preemption, timeslicing is specified on a task by task basis using the timeslicing mode flag (RTEMS_TIMESLICE_MASK). If timeslicing is enabled for a task (RTEMS_TIMESLICE), then RTEMS will limit the amount of time the task can execute before the processor is allocated to another task. Each tick of the real-time clock reduces the currently running task's timeslice. When the execution time equals the timeslice, RTEMS will dispatch another task of the same priority to execute. If there are no other tasks of the same priority ready to execute, then the current task is allocated an additional timeslice and continues to run. Remember that a higher priority task will preempt the task (unless preemption is disabled) as soon as it is ready to run, even if the task has not used up its entire timeslice.
