RTEMS Logo
RTEMS 4.10.0 On-Line Library
Dual-Ported Memory Manager PORT_DELETE - Delete a port
PREV UP NEXT Bookshelf RTEMS C User's Guide
15.4.3: PORT_DELETE - Delete a port
CALLING SEQUENCE:
rtems_status_code rtems_port_delete(
  rtems_id id
DIRECTIVE STATUS CODES:
RTEMS_SUCCESSFUL - port deleted successfully
RTEMS_INVALID_ID - invalid port id
DESCRIPTION:
This directive deletes the dual-ported memory area specified by id. The DPCB for the deleted dual-ported memory area is reclaimed by RTEMS.
NOTES:
This directive will not cause the calling task to be preempted.
The calling task does not have to be the task that created the port. Any local task that knows the port id can delete the port.
