RTEMS Logo
RTEMS 4.10.0 On-Line Library
Dual-Ported Memory Manager Converting an Address
PREV UP NEXT Bookshelf RTEMS C User's Guide
15.3.3: Converting an Address
The rtems_port_external_to_internal directive is used to convert an address from external to internal representation for the specified port. The rtems_port_internal_to_external directive is used to convert an address from internal to external representation for the specified port. If an attempt is made to convert an address which lies outside the specified DPMA, then the address to be converted will be returned.
