RTEMS Logo
RTEMS 4.10.0 On-Line Library
Signal Manager SIGNAL_CATCH - Establish an ASR
PREV UP NEXT Bookshelf RTEMS C User's Guide
12.4.1: SIGNAL_CATCH - Establish an ASR
CALLING SEQUENCE:
rtems_status_code rtems_signal_catch(
  rtems_asr_entry  asr_handler,
  rtems_mode mode
DIRECTIVE STATUS CODES:
RTEMS_SUCCESSFUL - always successful
DESCRIPTION:
This directive establishes an asynchronous signal routine (ASR) for the calling task. The asr_handler parameter specifies the entry point of the ASR. If asr_handler is NULL, the ASR for the calling task is invalidated and all pending signals are cleared. Any signals sent to a task with an invalid ASR are discarded. The mode parameter specifies the execution mode for the ASR. This execution mode supersedes the task's execution mode while the ASR is executing.
NOTES:
This directive will not cause the calling task to be preempted.
The following task mode constants are defined by RTEMS:
