RTEMS Logo
RTEMS 4.10.0 On-Line Library
Signal Manager Building a Signal Set
PREV UP NEXT Bookshelf RTEMS C User's Guide
12.2.3: Building a Signal Set
A signal set is built by a bitwise OR of the desired signals. The set of valid signals is RTEMS_SIGNAL_0 through RTEMS_SIGNAL_31. If a signal is not explicitly specified in the signal set, then it is not present. Signal values are specifically designed to be mutually exclusive, therefore bitwise OR and addition operations are equivalent as long as each signal appears exactly once in the component list.
This example demonstrates the signal parameter used when sending the signal set consisting of RTEMS_SIGNAL_6, RTEMS_SIGNAL_15, and RTEMS_SIGNAL_31. The signal parameter provided to the rtems_signal_send directive should be RTEMS_SIGNAL_6 | RTEMS_SIGNAL_15 | RTEMS_SIGNAL_31.
