RTEMS Logo
RTEMS 4.10.0 On-Line Library
Semaphore Manager Releasing a Semaphore
PREV UP NEXT Bookshelf RTEMS C User's Guide
9.3.4: Releasing a Semaphore
The rtems_semaphore_release directive is used to release the specified semaphore. A simplified version of the rtems_semaphore_release directive can be described as follows:
if no tasks are waiting on this semaphore
   then increment semaphore's count
   else assign semaphore to a waiting task
return SUCCESSFUL
If this is the outermost release of a binary semaphore that uses priority inheritance or priority ceiling and the task does not currently hold any other binary semaphores, then the task performing the rtems_semaphore_release will have its priority restored to its normal value.
