RTEMS Logo
RTEMS 4.10.0 On-Line Library
Timer Manager TIMER_RESET - Reset an interval timer
PREV UP NEXT Bookshelf RTEMS C User's Guide
8.4.10: TIMER_RESET - Reset an interval timer
CALLING SEQUENCE:
rtems_status_code rtems_timer_reset(
  rtems_id   id
DIRECTIVE STATUS CODES:
RTEMS_SUCCESSFUL - timer reset successfully
RTEMS_INVALID_ID - invalid timer id
RTEMS_NOT_DEFINED - attempted to reset a when or newly created timer
DESCRIPTION:
This directive resets the timer associated with id. This timer must have been previously initiated with either the rtems_timer_fire_after or rtems_timer_server_fire_after directive. If active the timer is canceled, after which the timer is reinitiated using the same interval and timer service routine which the original rtems_timer_fire_after rtems_timer_server_fire_after directive used.
NOTES:
If the timer has not been used or the last usage of this timer was by a rtems_timer_fire_when or rtems_timer_server_fire_when directive, then the RTEMS_NOT_DEFINED error is returned.
Restarting a cancelled after timer results in the timer being reinitiated with its previous timer service routine and interval.
This directive will not cause the running task to be preempted.
