RTEMS Logo
RTEMS 4.10.0 On-Line Library
Timer Manager TIMER_CANCEL - Cancel a timer
PREV UP NEXT Bookshelf RTEMS C User's Guide
8.4.3: TIMER_CANCEL - Cancel a timer
CALLING SEQUENCE:
rtems_status_code rtems_timer_cancel(
  rtems_id id
DIRECTIVE STATUS CODES:
RTEMS_SUCCESSFUL - timer canceled successfully
RTEMS_INVALID_ID - invalid timer id
DESCRIPTION:
This directive cancels the timer id. This timer will be reinitiated by the next invocation of rtems_timer_reset, rtems_timer_fire_after, or rtems_timer_fire_when with this id.
NOTES:
This directive will not cause the running task to be preempted.
