The timer manager provides support for timer facilities. The directives provided by the timer manager are:
rtems_timer_create - Create a timer
rtems_timer_ident - Get ID of a timer
rtems_timer_cancel - Cancel a timer
rtems_timer_delete - Delete a timer
rtems_timer_fire_after - Fire timer after interval
rtems_timer_fire_when - Fire timer when specified
rtems_timer_initiate_server - Initiate server for task-based timers
rtems_timer_server_fire_after - Fire task-based timer after interval
rtems_timer_server_fire_when - Fire task-based timer when specified
rtems_timer_reset - Reset an interval timer
