RTEMS Logo
RTEMS 4.10.0 On-Line Library
Clock Manager CLOCK_GET_TICKS_PER_SECOND - Get ticks per second
PREV UP NEXT Bookshelf RTEMS C User's Guide
7.4.6: CLOCK_GET_TICKS_PER_SECOND - Get ticks per second
CALLING SEQUENCE:
rtems_interval rtems_clock_get_ticks_per_second(void);
DIRECTIVE STATUS CODES:
NONE
DESCRIPTION:
This directive returns the number of clock ticks per second. This is strictly based upon the microseconds per clock tick that the application has configured.
NOTES:
This directive is callable from an ISR.
This directive will not cause the running task to be preempted. Re-initializing RTEMS causes the system date and time to be reset to an uninitialized state. Another call to rtems_clock_set is required to re-initialize the system date and time to application specific specifications.
