RTEMS Logo
RTEMS 4.10.0 On-Line Library
Task Manager TASK_SUSPEND - Suspend a task
PREV UP NEXT Bookshelf RTEMS C User's Guide
5.4.7: TASK_SUSPEND - Suspend a task
CALLING SEQUENCE:
rtems_status_code rtems_task_suspend(
  rtems_id id
DIRECTIVE STATUS CODES:
RTEMS_SUCCESSFUL - task restarted successfully
RTEMS_INVALID_ID - task id invalid
RTEMS_ALREADY_SUSPENDED - task already suspended
DESCRIPTION:
This directive suspends the task specified by id from further execution by placing it in the suspended state. This state is additive to any other blocked state that the task may already be in. The task will not execute again until another task issues the rtems_task_resume directive for this task and any blocked state has been removed.
NOTES:
The requesting task can suspend itself by specifying RTEMS_SELF as id. In this case, the task will be suspended and a successful return code will be returned when the task is resumed.
Suspending a global task which does not reside on the local node will generate a request to the remote node to suspend the specified task.
If the task specified by id is already suspended, then the RTEMS_ALREADY_SUSPENDED status code is returned.
