RTEMS Logo
RTEMS 4.10.0 On-Line Library
Task Manager Changing Task Priority
PREV UP NEXT Bookshelf RTEMS C User's Guide
5.3.6: Changing Task Priority
The rtems_task_set_priority directive is used to obtain or change the current priority of either the calling task or another task. If the new priority requested is RTEMS_CURRENT_PRIORITY or the task's actual priority, then the current priority will be returned and the task's priority will remain unchanged. If the task's priority is altered, then the task will be scheduled according to its new priority.
The rtems_task_restart directive resets the priority of a task to its original value.
