The task manager provides a comprehensive set of directives to create, delete, and administer tasks. The directives provided by the task manager are:
rtems_task_create - Create a task
rtems_task_ident - Get ID of a task
rtems_task_self - Obtain ID of caller
rtems_task_start - Start a task
rtems_task_restart - Restart a task
rtems_task_delete - Delete a task
rtems_task_suspend - Suspend a task
rtems_task_resume - Resume a task
rtems_task_is_suspended - Determine if a task is suspended
rtems_task_set_priority - Set task priority
rtems_task_mode - Change current task's mode
rtems_task_get_note - Get task notepad entry
rtems_task_set_note - Set task notepad entry
rtems_task_wake_after - Wake up after interval
rtems_task_wake_when - Wake up when specified
rtems_iterate_over_all_threads - Iterate Over Tasks
rtems_task_variable_add - Associate per task variable
rtems_task_variable_get - Obtain value of a a per task variable
rtems_task_variable_delete - Remove per task variable
