RTEMS Logo
RTEMS 4.10.0 On-Line Library
Overview RTEMS Application Architecture
PREV UP NEXT Bookshelf RTEMS C User's Guide
1.4: RTEMS Application Architecture
One important design goal of RTEMS was to provide a bridge between two critical layers of typical real-time systems. As shown in the following figure, RTEMS serves as a buffer between the project dependent application code and the target hardware. Most hardware dependencies for real-time applications can be localized to the low level device drivers.
The RTEMS I/O interface manager provides an efficient tool for incorporating these hardware dependencies into the system while simultaneously providing a general mechanism to the application code that accesses them. A well designed real-time system can benefit from this architecture by building a rich library of standard application components which can be used repeatedly in other real-time projects.
