RTEMS Logo
RTEMS 4.10.0 On-Line Library
Discrete Driver Enable Discrete Outputs
PREV UP NEXT Bookshelf BSP and Device Driver Development Guide
19.9: Enable Discrete Outputs
This is one of the IOCTL functions supported by the I/O control device driver entry point. When this IOCTL function is invoked, the discrete outputs are enabled.
NOTE: It may not be possible to disable/enable discrete output on all discrete I/O boards.
