BSP and Device Driver Development Guide
The frame_buffer_read() is invoked from a read() operation
on the frame buffer device.
Read functions should allow normal and partial reading at the end of frame buffer memory.
This method returns RTEMS_SUCCESSFUL when the device is successfully read from:
rtems_device_driver frame_buffer_read(
rtems_device_major_number major,
rtems_device_minor_number minor,
void *arg
rtems_libio_rw_args_t *rw_args = (rtems_libio_rw_args_t *)arg;
rw_args->bytes_moved = ((rw_args->offset + rw_args->count) > fb_fix.smem_len ) ? (fb_fix.smem_len - rw_args->offset) : rw_args->count;
memcpy(rw_args->buffer, (const void *) (fb_fix.smem_start + rw_args->offset), rw_args->bytes_moved);
return RTEMS_SUCCESSFUL;
