BSP and Device Driver Development Guide
The frame_buffer_open() function is called whenever a frame buffer device is opened.
If the frame buffer is registered as "/dev/fb0", the frame_buffer_open entry point
will be called as the result of an open("/dev/fb0", mode) in the application.
Thread safety of the frame buffer driver is implementation-dependent. The VGA driver shown below uses a mutex to prevent multiple open() operations of the frame buffer device.
The frame_buffer_open() function returns RTEMS_SUCCESSFUL when the device driver
is successfully opened, and RTEMS_UNSATISFIED if the device is already open:
rtems_device_driver frame_buffer_close(
rtems_device_major_number major,
rtems_device_minor_number minor,
void *arg
if (pthread_mutex_unlock(&mutex) == 0){
/* restore previous state. for VGA this means return to text mode.
* leave out if graphics hardware has been initialized in
* frame_buffer_initialize() */
ega_hwterm();
printk( "FBVGA close called.\n" );
return RTEMS_SUCCESSFUL;
return RTEMS_UNSATISFIED;
In the previous example, the function ega_hwinit() takes care of
hardware-specific initialization.
