RTEMS Logo
RTEMS 4.10.0 On-Line Library
Shared Memory Support Driver Releasing a Shared Lock
PREV UP NEXT Bookshelf BSP and Device Driver Development Guide
16.2.3.3: Releasing a Shared Lock
The Shm_Unlock routine is responsible for releasing the lock field and reenabling processor interrupts. This routines usually is implemented as follows:
void Shm_Unlock(
  Shm_Locked_queue_Control *lq_cb
  set the lock to the unlocked value
  reenable processor interrupts to their level prior
    to the lock being acquired.  This value was saved
    in the global variable Shm_isrstat
