RTEMS Logo
RTEMS 4.10.0 On-Line Library
Real-Time Clock Driver checkRealTime
PREV UP next Bookshelf BSP and Device Driver Development Guide
11.7: checkRealTime
The checkRealTime routine returns the number of seconds difference between the RTC TOD and the current RTEMS TOD.
int checkRealTime( void )
  if no RTCs are present
    return -1
  obtain the RTEMS TOD using rtems_clock_get
  get the TOD from the preferred RTC using the deviceGetTime routine
  convert the RTEMS TOD to seconds
  convert the RTC TOD to seconds
  return the RTEMS TOD in seconds - RTC TOD in seconds
