RTEMS Logo
RTEMS 4.10.0 On-Line Library
Miscellaneous Support Files bsp_cleanup() - Cleanup the Hardware
PREV UP NEXT Bookshelf BSP and Device Driver Development Guide
5.9: bsp_cleanup() - Cleanup the Hardware
The bsp_cleanup() is the last C code invoked. Most of the BSPs use the same shared version of bsp_cleanup() that does nothing. This implementation is located in the following file:
c/src/lib/libbsp/shared/bspclean.c
The bsp_cleanup() routine can be used to return to a ROM monitor, insure that interrupt sources are disabled, etc.. This routine is the last place to insure a clean shutdown of the hardware. On some BSPs, it prints a message indicating that the application completed execution and waits for the user to press a key before resetting the board. The PowerPC/gen83xx and PowerPC/gen5200 BSPs do this when they are built to support the FreeScale evaluation boards. This is convenient when using the boards in a development environment and may be disabled for production use.
