RTEMS Logo
RTEMS 4.10.0 On-Line Library
Ada95 Interrupt Support Version Requirements
PREV UP NEXT Bookshelf BSP and Device Driver Development Guide
6.4: Version Requirements
With RTEMS 4.0, a patch was required to psignal.c in RTEMS sources (to correct a bug associated to the default action of signals 15-32). The SPARC/ERC32 RTEMS BSP includes the gnatsupp subdirectory that can be used as an example for other BSPs.
With GNAT 3.11p, a patch is required for a-init.c to invoke the BSP specific routine that installs the exception handlers.
