RTEMS Logo
RTEMS 4.10.0 On-Line Library
Linker Script What is a "linkcmds" file?
PREV UP NEXT Bookshelf BSP and Device Driver Development Guide
4.1: What is a "linkcmds" file?
The linkcmds file is a script which is passed to the linker at linking time. This file describes the memory configuration of the board as needed to link the program. Specifically it specifies where the code and data for the application will reside in memory.
The format of the linker script is defined by the GNU Loader ld which is included as a component of the GNU Binary Utilities. If you are using GNU/Linux, then you probably have the documentation installed already and are using these same tools configured for native use. Please visit the Binutils project if you need more information.
