RTEMS Logo
RTEMS 4.10.0 On-Line Library
Target Dependent Files Board Dependent
PREV UP NEXT Bookshelf BSP and Device Driver Development Guide
2.2: Board Dependent
This class of code provides the most specific glue between RTEMS and a particular board. This code is represented by the Board Support Packages and associated Device Drivers. Sources for the BSPs included in the RTEMS distribution are located in the directory c/src/lib/libbsp. The BSP source directory is further subdivided based on the CPU family and BSP.
Some BSPs may support multiple board models within a single board family. This is necessary when the board supports multiple variants on a single base board. For example, the Motorola MVME162 board family has a fairly large number of variations based upon the particular CPU model and the peripherals actually placed on the board.
