RTEMS Logo
RTEMS 4.10.0 On-Line Library
Directive Status Codes
Chapter 29: Directive Status Codes
RTEMS.SUCCESSFUL - successful completion
RTEMS.TASK_EXITTED - returned from a task
RTEMS.MP_NOT_CONFIGURED - multiprocessing not configured
RTEMS.INVALID_NAME - invalid object name
RTEMS.INVALID_ID - invalid object id
RTEMS.TOO_MANY - too many
RTEMS.TIMEOUT - timed out waiting
RTEMS.OBJECT_WAS_DELETED - object was deleted while waiting
RTEMS.INVALID_SIZE - invalid specified size
RTEMS.INVALID_ADDRESS - invalid address specified
RTEMS.INVALID_NUMBER - number was invalid
RTEMS.NOT_DEFINED - item not initialized
RTEMS.RESOURCE_IN_USE - resources outstanding
RTEMS.UNSATISFIED - request not satisfied
RTEMS.INCORRECT_STATE - task is in wrong state
RTEMS.ALREADY_SUSPENDED - task already in state
RTEMS.ILLEGAL_ON_SELF - illegal for calling task
RTEMS.ILLEGAL_ON_REMOTE_OBJECT - illegal for remote object
RTEMS.CALLED_FROM_ISR - invalid environment
RTEMS.INVALID_PRIORITY - invalid task priority
RTEMS.INVALID_CLOCK - invalid time buffer
RTEMS.INVALID_NODE - invalid node id
RTEMS.NOT_CONFIGURED - directive not configured
RTEMS.NOT_OWNER_OF_RESOURCE - not owner of resource
RTEMS.NOT_IMPLEMENTED - directive not implemented
RTEMS.INTERNAL_ERROR - RTEMS inconsistency detected
RTEMS.NO_MEMORY - could not get enough memory
