RTEMS Logo
RTEMS 4.10.0 On-Line Library
Chains Is Null Node ?
28.4.3: Is Null Node ?
CALLING SEQUENCE:
RETURNS
Returns true is the node point is NULL and false if the node is not NULL.
DESCRIPTION:
Tests the node to see if it is a NULL returning true if a null.
