RTEMS Logo
RTEMS 4.10.0 On-Line Library
Chains Initialize Chain With Nodes
28.4.1: Initialize Chain With Nodes
CALLING SEQUENCE:
RETURNS
Returns nothing.
DESCRIPTION:
This function take in a pointer to a chain control and initializes it to contain a set of chain nodes. The chain will contain number_nodes chain nodes from the memory pointed to by start_address. Each node is assumed to be node_size bytes.
NOTES:
This call will discard any nodes on the chain.
This call does NOT inititialize any user data on each node.
