RTEMS Logo
RTEMS 4.10.0 On-Line Library
Object Services OBJECT_ID_GET_API - Obtain API from Id
27.4.5: OBJECT_ID_GET_API - Obtain API from Id
CALLING SEQUENCE:
procedure Object_Id_Get_API(
   ID  : in     RTEMS.ID;
   API :    out RTEMS.Unsigned32
DIRECTIVE STATUS CODES
Returns the API portion of the object Id.
DESCRIPTION:
This directive returns the API portion of the provided object id.
NOTES:
This directive is strictly local and does not impact task scheduling.
This directive does NOT validate the id provided.
