RTEMS Logo
RTEMS 4.10.0 On-Line Library
Multiprocessing Manager RETURN_PACKET
24.3.3: RETURN_PACKET
The RETURN_PACKET component of the user-provided MPCI layer is called when RTEMS needs to release a packet to the free packet buffer pool. This component should be adhere to the following prototype:
rtems_mpci_entry user_mpci_return_packet(
  rtems_packet_prefix *packet
where packet is the address of a packet. If the packet cannot be successfully returned, the fatal error manager should be invoked.
