RTEMS Logo
RTEMS 4.10.0 On-Line Library
Multiprocessing Manager Multiprocessor Configuration Table
24.2.6: Multiprocessor Configuration Table
The Multiprocessor Configuration Table contains information needed by RTEMS when used in a multiprocessor system. This table is discussed in detail in the section Multiprocessor Configuration Table of the Configuring a System chapter.
