RTEMS Logo
RTEMS 4.10.0 On-Line Library
Configuring a System POSIX API Configuration
23.2.8: POSIX API Configuration
The parameters in this section are used to configure resources for the RTEMS POSIX API. They are only relevant if the POSIX API is enabled at configure time using the --enable-posix option.
