RTEMS Logo
RTEMS 4.10.0 On-Line Library
Configuring a System Multiprocessing Configuration
23.2.5: Multiprocessing Configuration
This section defines the multiprocessing related system configuration parameters supported by rtems/confdefs.h. This class of Configuration Constants are only applicable if CONFIGURE_MP_APPLICATION is defined.
