RTEMS Logo
RTEMS 4.10.0 On-Line Library
User Extensions Manager EXTENSION_DELETE - Delete a extension set
22.4.3: EXTENSION_DELETE - Delete a extension set
CALLING SEQUENCE:
procedure Extension_Delete (
   ID     : in     RTEMS.ID;
   Result :    out RTEMS.Status_Codes
DIRECTIVE STATUS CODES:
RTEMS.SUCCESSFUL - extension set deleted successfully
RTEMS.INVALID_ID - invalid extension set id
DESCRIPTION:
This directive deletes the extension set specified by id. If the extension set is running, it is automatically canceled. The ESCB for the deleted extension set is reclaimed by RTEMS.
NOTES:
This directive will not cause the running task to be preempted.
A extension set can be deleted by a task other than the task which created the extension set.
NOTES:
