RTEMS Logo
RTEMS 4.10.0 On-Line Library
User Extensions Manager EXTENSION_CREATE - Create a extension set
22.4.1: EXTENSION_CREATE - Create a extension set
CALLING SEQUENCE:
procedure Extension_Create (
   Name   : in     RTEMS.Name;
   Table  : in     RTEMS.Extensions_Table_Pointer;
   ID     :    out RTEMS.ID;
   Result :    out RTEMS.Status_Codes
DIRECTIVE STATUS CODES:
RTEMS.SUCCESSFUL - extension set created successfully
RTEMS.INVALID_NAME - invalid extension set name
RTEMS.TOO_MANY - too many extension sets created
DESCRIPTION:
This directive creates a extension set. The assigned extension set id is returned in id. This id is used to access the extension set with other user extension manager directives. For control and maintenance of the extension set, RTEMS allocates an ESCB from the local ESCB free pool and initializes it.
NOTES:
This directive will not cause the calling task to be preempted.
