RTEMS Logo
RTEMS 4.10.0 On-Line Library
Barrier Manager Deleting a Barrier
20.3.5: Deleting a Barrier
The rtems.barrier_delete directive removes a barrier from the system and frees its control block. A barrier can be deleted by any local task that knows the barrier's ID. As a result of this directive, all tasks blocked waiting for the barrier to be released, will be readied and returned a status code which indicates that the barrier was deleted. Any subsequent references to the barrier's name and ID are invalid.
