The rtems.barrier_create directive creates
a barrier with a user-specified name and the desired attributes.
RTEMS allocates a Barrier Control Block (BCB) from the BCB free list.
This data structure is used by RTEMS to manage the newly created
barrier. Also, a unique barrier ID is generated and returned to
the calling task.
