RTEMS Logo
RTEMS 4.10.0 On-Line Library
Barrier Manager Automatic Versus Manual Barriers
20.2.1: Automatic Versus Manual Barriers
Just as with a real-world gate, barriers may be configured to be manually opened or automatically opened. All tasks calling the rtems.barrier_wait directive will block until a controlling task invokes the rtems.barrier_release directive.
Automatic barriers are created with a limit to the number of tasks which may simultaneously block at the barrier. Once this limit is reached, all of the tasks are released. For example, if the automatic limit is ten tasks, then the first nine tasks calling the rtems.barrier_wait directive will block. When the tenth task calls the rtems.barrier_wait directive, the nine blocked tasks will be released and the tenth task returns to the caller without blocking.
