RTEMS Logo
RTEMS 4.10.0 On-Line Library
Rate Monotonic Manager RATE_MONOTONIC_REPORT_STATISTICS - Print period statistics report
19.4.10: RATE_MONOTONIC_REPORT_STATISTICS - Print period statistics report
CALLING SEQUENCE:
procedure Rate_Monotonic_Report_Statistics;
DIRECTIVE STATUS CODES:
NONE
DESCRIPTION:
This directive prints a report on all active periods which have executed at least one period. The following is an example of the output generated by this directive.
NOTES:
This directive will not cause the running task to be preempted.
