RTEMS Logo
RTEMS 4.10.0 On-Line Library
Rate Monotonic Manager RATE_MONOTONIC_DELETE - Delete a rate monotonic period
19.4.4: RATE_MONOTONIC_DELETE - Delete a rate monotonic period
CALLING SEQUENCE:
procedure Rate_Monotonic_Delete (
   ID     : in     RTEMS.ID;
   Result :    out RTEMS.Status_Codes
DIRECTIVE STATUS CODES:
RTEMS.SUCCESSFUL - period deleted successfully
RTEMS.INVALID_ID - invalid rate monotonic period id
DESCRIPTION:
This directive deletes the rate monotonic period specified by id. If the period is running, it is automatically canceled. The PCB for the deleted period is reclaimed by RTEMS.
NOTES:
This directive will not cause the running task to be preempted.
A rate monotonic period can be deleted by a task other than the task which created the period.
