RTEMS 4.10.0 On-Line Library
Rate Monotonic Manager Assumptions
RTEMS Ada User's Guide
19.2.5.1: Assumptions
The schedulability analysis rules for RMS were
developed based on the following assumptions:
- The requests for all tasks for which hard deadlines
exist are periodic, with a constant interval between requests.
- Each task must complete before the next request for it
occurs.
- The tasks are independent in that a task does not depend
on the initiation or completion of requests for other tasks.
- The execution time for each task without preemption or
interruption is constant and does not vary.
- Any non-periodic tasks in the system are special. These
tasks displace periodic tasks while executing and do not have
hard, critical deadlines.
Once the basic schedulability analysis is understood,
some of the above assumptions can be relaxed and the
side-effects accounted for.
