RTEMS Logo
RTEMS 4.10.0 On-Line Library
I/O Manager Device Driver Table
16.2.1: Device Driver Table
Each application utilizing the RTEMS I/O manager must specify the address of a Device Driver Table in its Configuration Table. This table contains each device driver's entry points that is to be initialised by RTEMS during initialization. Each device driver may contain the following entry points:
If the device driver does not support a particular entry point, then that entry in the Configuration Table should be NULL. RTEMS will return RTEMS.SUCCESSFUL as the executive's and zero (0) as the device driver's return code for these device driver entry points.
Applications can register and unregister drivers with the RTEMS I/O manager avoiding the need to have all drivers statically defined and linked into this table.
The `confdefs.h' entry CONFIGURE_MAXIMUM_DRIVERS configures the number of driver slots available to the application.
