RTEMS 4.10.0 On-Line Library
I/O Manager Directives
RTEMS Ada User's Guide
16.4: Directives
I/O Manager IO_REGISTER_DRIVER - Register a device driver
I/O Manager IO_UNREGISTER_DRIVER - Unregister a device driver
I/O Manager IO_INITIALIZE - Initialize a device driver
I/O Manager IO_REGISTER_NAME - Register a device
I/O Manager IO_LOOKUP_NAME - Lookup a device
I/O Manager IO_OPEN - Open a device
I/O Manager IO_CLOSE - Close a device
I/O Manager IO_READ - Read from a device
I/O Manager IO_WRITE - Write to a device
I/O Manager IO_CONTROL - Special device services
This section details the I/O manager's directives. A
subsection is dedicated to each of this manager's directives and
describes the calling sequence, related constants, usage, and
status codes.
