RTEMS Logo
RTEMS 4.10.0 On-Line Library
Dual-Ported Memory Manager Directives
15.4: Directives
  • Dual-Ported Memory Manager PORT_CREATE - Create a port
  • Dual-Ported Memory Manager PORT_IDENT - Get ID of a port
  • Dual-Ported Memory Manager PORT_DELETE - Delete a port
  • Dual-Ported Memory Manager PORT_EXTERNAL_TO_INTERNAL - Convert external to internal address
  • Dual-Ported Memory Manager PORT_INTERNAL_TO_EXTERNAL - Convert internal to external address
  • This section details the dual-ported memory manager's directives. A subsection is dedicated to each of this manager's directives and describes the calling sequence, related constants, usage, and status codes.
